Toyota AE86 LSD
Toyota AE86 LSD
Last weekend GB_BB4C and I spotted a TRD LSD from a AE86 Corolla/Levin and besides these are the right stud pattern for us they also look like they are the right width, the Jap importer only wanted $1400 for it.
We also noticed these are a 10 bolt and look identical to Scorpion/EX Lancer 10 bolts.
Has anyone had any experience with these centres?
Anyone know if they will fit into our housings?
Re: Toyota AE86 LSD
One question,
When you say the right width.....what are you comparing it to?
Galant?,Lance/Sigma?Scorpion?
Did this AE86 diff have drums or discs?
Do you know what ratio?
Sorry, that was about 9 questions i know....but am curious
Re: Toyota AE86 LSD
Not sure if they came with drums, but I know for sure that they do come with discs.Scorpma82 wrote:Did this AE86 diff have drums or discs?
Shoot this guy a question, and get him to measure from hub face to hub face.Scorpma82 wrote:When you say the right width.....what are you comparing it to?
http://www.ebay.com.au/itm/Ae86-jdm-dis ... 500wt_1156
I've seen these a lot cheaper, but this is all that's on ebay atm.
http://www.ebay.com.au/itm/kaaz-Lsd-REA ... 949wt_1870
I'm pretty sure there are different ratios available? The good thing about the 86 diffs, is so many people use them (for drifting/racing etc..) that it's worth the effort for suppliers to make things for them, because they have a market to sell to.Scorpma82 wrote:Do you know what ratio?
I have seen 1 ways, 1.5ways and 2 ways advertised for them on ebay before.
Re: Toyota AE86 LSD
This particular diff was discs, but like Dave said I think drum were available but discs only for LS optioned diffs.Scorpma82 wrote:One question,
Width looks pretty close to Sigma, maybe slightly narrower so would suit Sigma and Galant.
Cusco, TRD, KAAS and I am sure others all do kits for these diffs, you could get any ratio you wanted.
Re: Toyota AE86 LSD
hmmmmmmm, so in theory, is it possible that you could get an open diff from an Aus model Corolla or Corona and put in an LSD centre into them????
Re: Toyota AE86 LSD
I don't know for sure, but I'd say this site may just be able to answer that question.Scorpma82 wrote:so in theory, is it possible that you could get an open diff from an Aus model Corolla or Corona and put in an LSD centre into them????
http://www.ae86drivingclub.com.au/forum ... 0a829241e6
Re: Toyota AE86 LSD
The diff in question is a T series, so T18, RA40 or JDM AE86. Two different sizes, for early AE86/T18/RA40 and late AE86. RA40/T18 have drum brakes.
The only real advantage they'd have is the ready availability of different ratios and LSD centres, they're about as strong as a Scorpion diff.
Re: Toyota AE86 LSD
No. Aus Corollas/Coronas have Borg-Warner diffs. Pretty sure it's the same diff as a Sigma actually. AUDM AE86's have an S-series, which is just as shit.Scorpma82 wrote:hmmmmmmm, so in theory, is it possible that you could get an open diff from an Aus model Corolla or Corona and put in an LSD centre into them????
Re: Toyota AE86 LSD
Are the centres interchangeable with Scorpion 10 bolts?
Re: Toyota AE86 LSD
I highly doubt it, but you never know.
Know anyone with a shitty old RA40 Celica just sitting about? lol
Re: Toyota AE86 LSD
If this is correct one would assume the 10 bolts were the same diff too. I am pretty sure there are a couple of RA40's at Up Pull It north, I will check them out next weekend.webby wrote: No. Aus Corollas/Coronas have Borg-Warner diffs. Pretty sure it's the same diff as a Sigma actually. AUDM AE86's have an S-series, which is just as shit.
Re: Toyota AE86 LSD
Wouldn't count on it. The 10-bolt and T-series were made by Mitsubishi and Toyota respectively, not sourced from a third party company like the Sigma/Corona/Corolla BW70.
Edit: But like I said before, you never know
