Scorp Diff Conversion
GC26T
Post by GC26T »
After popping my standard GC diff on a quick change from first to second, and having a GL Scorp diff kicking around, I've decided to do the conversion.
Just a couple of question though... Does the tail shaft have to be shortened? I've got the diff sitting in position, and to me, the shaft hasn't got much travel
in the gearbox before bottoming out. What ratios are available for them? I've got an L300 centre with a 4.6 ratio or the standard 3.3 Scorp ratio. Isn't there something
in between? Thanks for your help
stealth
Re: Scorp Diff Conversion
Post by stealth »
mate which scorp diff is it
is it a 10 bolt or a 8 bolt?
if its a 8 bolt theres more options but dont know about
the 10 bolt
borgys suck thay were only 23 spline dont use them its
a waste of time,money and effort
cheers stealth 8-)
GC26T
Post by GC26T »
I didn't think any Scorps had borgys? Every one I've seen is Jap banjo. It's 10 bolt out of a 85 GL Scorpion BTW.
stealth
Post by stealth »
fare enough i wasnt sure about scorp diff
as far as 10 bolt goes i got no idea but there has been a few posts
regaurding 10 bolt maybe do a seach on the old site
cheers stealth 8-)
bmxwrx
Post by bmxwrx »
There's nothing in between and they are all open centre.
BIG26L
Post by BIG26L »
If its a 10bolt (2.6L-GH onwards) there are quite a few ratio's available
3.33, 3.55, 3.93, 4.222, 4.675, 4.825.
If you have a hunt threw the early to mid 80's Mitsu's (L200, L300,pajero, scorpion, starion) you will find the ratio you need.
LSD's will be an issue, Starion and Pajero fit the case, but you can't get side gears to suit the scorpion axles.
I did all the research for this stuff in the mid to late 90's. When we were looking for ratio's for my IPRA Lancer back then.
Hope this helps......
