La lancer diff
mstrrab1992
La lancer diff
Post by mstrrab1992 »
What would be a suitable replacement diff thatd fit into my la lancer thatd be alot stronger
Torana68
Re: La lancer diff
Post by Torana68 »
do a search they have all been mentioned before, what engine and HP?
mstrrab1992
Re: La lancer diff
2.6 astron nd idk able to handle alot if i decide to turbo
astronturbo77
Re: La lancer diff
Post by astronturbo77 »
sounds like you need to stick with the standard diff.
mstrrab1992
Re: La lancer diff
Whys that
Rally_2.6LC
Re: La lancer diff
Post by Rally_2.6LC »
LC lancer diff is straight bolt in that is stronger by a bit (thicker axles). If you want it to handle stupid power get a custom one or shortened Hilux (bit of work involved in conversion).
Or Scorpion diff (but again modification of mounts) and it is also a bit wider....not a problem if you have flares though.......
Cheers Matt
'75 GC daily (slowly dying)
^This side up^
Formely "Matt"
mstrrab1992
Re: La lancer diff
thanks buddy
Re: La lancer diff
I bought one from a EX Lancer turbo for the hardtop. It is LSD with nice thick axles and has vented disc brakes :thumpsup:
mstrrab1992
Re: La lancer diff
if u install it for me :D!
mstrrab1992
Re: La lancer diff
i may just leave it or get a LC Diff (FOR NOW)
rx22nv
Re: La lancer diff
Post by rx22nv »
I had an LA lancer with a 13b turbo. I ran the LC lancer diff and a welded centre. They last ok but if it axle tramps it will pretty much blow instantly. Save for the hilux too.
77lancer
Re: La lancer diff
Post by 77lancer »
im selling my lb with a lv turbo diff already cut down for only $500
