short shifter ?
turbol200
short shifter ?
Post by turbol200 »
has any one had a go at making some spacers up and moving the pivot on a jap 5 speed gear stick to give it a shorter throw ?
spoto a 57 chev
...a 57 2 door
GB_BB4C
Re: short shifter ?
Post by GB_BB4C »
Working on one at the moment. Still in progress though. Just need a spacer to raise the mounting bolts a bit higher and somethin to extend the end of the shifter (ball part)
The origional shifter is made of hardened steel. i am going to use a hardened bolt and weld it together. (wish i had a lathe or access to one)
turbol200
Re: short shifter ?
Post by turbol200 »
thats what i had in mind for it, the only thing i was thinking a bout was would the shifter hit the spacer if it was made to high ? if ya know what i mean
spoto a 57 chev
...a 57 2 door
GB_BB4C
Re: short shifter ?
Post by GB_BB4C »
In short, No (makes sure hole in spacer is the same size as one in the gearbox). The shifter still moves the same at the gearbox end, but the knob end moves less. Guestimatios of movment are only there for example purposes only, i have not worked out how much it will reduce it by,
mstrrab1992
Re: short shifter ?
Post by mstrrab1992 »
Just cut the shifter in half and crazy glue the knob on, muahahaha
turbol200
Re: short shifter ?
Post by turbol200 »
oh yer lol now i seen the pic i remembered the gearbox end moves the same :facepalm:
spoto a 57 chev
...a 57 2 door
Re: short shifter ?
I would be interested in one of these if you are making them as a kit.
robbert
Re: short shifter ?
Post by robbert »
I used to cut the gear stick in half then drill out the rubber inside it. Then slide the top of the stick up through the bottom. Then u have a shorter stick with the thread.
mstrrab1992
Re: short shifter ?
V nice
turbol200
Re: short shifter ?
Post by turbol200 »
thats what has been done on my wagon lol, but dont wana have to move my hand so far from the wheel sorta thing, so there for the spacer thing
spoto a 57 chev
...a 57 2 door
