Flywheel?
SpEc_OpS
Flywheel?
Post by SpEc_OpS »
Hey everyone im in search of a flywheel from a 2L astron i have rung pretty much every sydney wrecker and am having no luck if any1 knows where i could get 1 or an aftermarket 1 or if any other model cars have 1 that will do the job with no modifications thnx guys
Drive It Like You Stole It
The Drifter = 99 VS Ute (Kaaz 2 way LSD + 3.8 v6 on boost :lol:)
The Old Drifter = 99 S15 Spec-R (GONE :()
The Project = 80 GH Scorp (shes getting there)
The Fourby = 92 4Runner (can climb yo mumma)
The Daily = 95 Camry (the gf gotta have a car too)
The Shitter = 89 Hiace (with ever panel customised)
The Untamed = 98 cbr 600 (nearly killed me twice but i still love her)
SpEc_OpS
Re: Flywheel?
Post by SpEc_OpS »
TUFSIG wrote:i have one sitting here however its got a slight hairline crack in it so i dont know if you would want that lol
How bad is this hairline crack n how much u want for it?
txt me (number removed) or call wateva i dnt care thnx dude names adam btw
cheaterparts
Re: Flywheel?
Post by cheaterparts »
SpEc_OpS wrote:Hey everyone im in search of a flywheel from a 2L astron i have rung pretty much every sydney wrecker and am having no luck if any1 knows where i could get 1 or an aftermarket 1 or if any other model cars have 1 that will do the job with no modifications thnx guys
I may have one out in the shed if its there you can have it but I am in melb though . I wont use cast flywheels in my engines anyway ,for what I wont they are to heavy and I wouldn't dream of putting anything on my crank with a crack in it.
I even dont wont to use a clutch with a cast presure plate - not after exploding one at sandown
wheelnut
Re: Flywheel?
Post by wheelnut »
get a 2.6 magna one and get a machine shop to bore out centre hole to suit the sigma spiggot.
gb galant efi 2.6 track toy
gj sedan hack car
SpEc_OpS
Re: Flywheel?
Post by SpEc_OpS »
wheelnut wrote:get a 2.6 magna one and get a machine shop to bore out centre hole to suit the sigma spiggot.
Will it be as strong as a normal 1 wats pros cons of doing this eg is it lighter or anything?
C_Fernance
Re: Flywheel?
Post by C_Fernance »
It will be a lot stronger than a cracked one.
SpEc_OpS
Re: Flywheel?
Post by SpEc_OpS »
C_Fernance wrote:It will be a lot stronger than a cracked one.
Well i was planning on welding the shit outta it then getting it machined but have since found 1 from cheaterparts without ring gear tho magna 1 should fit straight up tho shouldnt it?
C_Fernance
Re: Flywheel?
I believe the ring gear is the same. A lot of people run Magna starter motors in a Sigma and vice-versa.
Torana68
Re: Flywheel?
Post by Torana68 »
......welding a flywheel would be a big no no.....
karl_2ltgc
Re: Flywheel?
Post by karl_2ltgc »
C_Fernance wrote:I believe the ring gear is the same. A lot of people run Magna starter motors in a Sigma and vice-versa.
Yea i run a magna starter. Reduction drive means faster cranking and easier starting. Plus there all about 10 years newer and plenty in wrecking yards.
SpEc_OpS
Re: Flywheel?
Post by SpEc_OpS »
Interesting cos my car has trubl starting sometimes are they a straight bolt in swap i mite get 1 if they are. How much did u pay for yours karl?
karl_2ltgc
Re: Flywheel?
Straight bolt in.
I just picked mine up at the wreckers, probably $30 or so. Heaps of magnas just try to find one that looks like a reco.
panda
Re: Flywheel?
Post by panda »
Reduction starter is the way to go. Spins the crank faster, & easier on the battery. Brand new costs $120~$160, or much less S/H, typically $50~$100. Also S/H ones will be much newer the stock S/H starters.
SpEc_OpS
Re: Flywheel?
Post by SpEc_OpS »
Cheers guys might do that when i was ordering parts from auto1 the other day i had a look in the book and apparantly my car supposed to have a battery with 600CCA (cold cranking amps)
thats nuts i think. Any1 have an idea wat size battery the magna has? when i bought the car it only had a 520CCA battery in it so i have to use another battery to start it everytime so annoying.
panda
Re: Flywheel?
Post by panda »
My rally Sigma has only a 360CCA battery. No problem starting using a reduction starter after sitting idle for a month between events. :P In fact I recently drove it into the shed on the starter motor when I ran out of fuel. A 520CCA battery should have power to spare, or the battery is past its use by date.
Also I have real heavy duty battery leads, good quality battery terminals, plus the motor is earthed to the chassis rails on both sides of the motor. All this makes a difference, together with a 100 Amp alternator.
