4g54 a/t - m/t in search of jap 5 spd and diff qs?
Posted: Sat Apr 18, 2009 11:26 pm
by SpEc_OpS
Hi all looking for a jap 5 speed any1 got suggestions where i shuld be looking n roughly how much they worth? im going to turbo the 2.6 prbly be putting out 150-200 kw at the treads so dnt think the standard 5 speed will hold up tell me wat u guys think
also wondering wat lsd options do i have are they very strong or shuld i jus mini spool it?
Re: 4g54 a/t - m/t in search of jap 5 spd and diff qs?
Posted: Sun Apr 19, 2009 10:31 am
by Sigmaproject
Depends on how you drive it. There are guys on the forum with 200+ still using the Jap 5 speed. To upgrade is big bikkies
Dont forget when looking for a Jap that there are two belhousing stud pattens. Measure the 2 lower/outer bellhousing bolt holes on the motor and get a gearbox to match. Will be either 310mm or 330mm.
Posted: Sun Apr 19, 2009 11:16 am
by SpEc_OpS
im sure the jap 5 speed will hold up but i was wondering will the standard 5 speed i do kinda thrash my cars tho so yeh prbly go the jap box but i got no idea where to get 1
Posted: Sun Apr 19, 2009 12:57 pm
by 81GL
The wreckers is always a good start? (look for one with the lowest number on the odo too
From your other thread, you have an auto yeah? you'll need a gearbox thats is behind a 2lt astron, & while your there, grab the flywheel too, probably wise to also grab the speedo cable & the front bit of the tail shaft that goes into the gear box. you may or may not find that you will need a different length tail shaft (theres too many variable to say.)
Diff? you should already have a 10-bolt diff in there being a scorp, weld it up, should last a while.
Nick.
PS: oh... 'jap' box's have reverse bottom right on the H, if its top left, run like hell
Posted: Sun Apr 19, 2009 2:51 pm
by Frosty
The "jap" 5 speeds are the most common in the sigmas and scorpions. I think they're called the KM132
just about any manual sigma or scorpion from about 1980 onwards should have the jap 5 speed.
and some of the early 1978 2.0L sigmas were jap 5spd as well.
like 81GL said, you want the one where reverse gear is located on the rear right. like this
1 3 5 <<JAP 5 SPD
2 4 R
Posted: Sun Apr 19, 2009 3:12 pm
by SpEc_OpS
Cool thnx guys i thort they were rare how much they usually go for?
Posted: Sun Apr 19, 2009 3:37 pm
by Frosty
you can probably get a pranged car with a good 5 speed for $100 and remove it yourself. i've done that a few times coz it's cheaper than buying parts already removed.
or you could check pick-a-part and those kinda places. as well as ebay and the trading post.
things like that.
Posted: Sun Apr 19, 2009 3:52 pm
by Sigmaproject
The Borg Warner boxes have a separate bellhousing, where the Jap has the bellhousing cast as part of the caseing.
Posted: Mon Apr 20, 2009 9:58 am
by SpEc_OpS
Ok guys found a place that stocks and recos them whole unit for $880 including reco number below for anyone interested.
a qs tho do i need the 1 with the longer shaft or not? Apparantly theres a 2 inch difference a speedy response would be awesome as i plan on doing the conversion this weekend and he needs time to reco the box thnx guys.
The gearbox Factory
(02)97721642
28 queen st Revesby nsw
Posted: Mon Apr 20, 2009 11:10 am
by Superscan811
WAIT...
$880 sounds a bit steep unless that is an outright purchase (ie: no changeover gearbox required)
I had a Starion turbo gearbox reconditioned (jap wide block but stronger internals than the Scorp/Sigma) for $600 and it was a complete rebuild.
If the gearbox is in reasonable condition it's around $300-$400.
The GE and GH Scorps have the shorter gearboxes, GJ onwards have the longer boxes.
Posted: Mon Apr 20, 2009 11:28 am
by SpEc_OpS
yeh thats an outright purchase including the shifter plus reco i might enquire as to if they do want my auto box see if i can get it cheaper.
Does anyone know if the manual box will fit the auto yoke?
Also im having alot of trouble finding a flywheel are there any aftermarket options or is there one from another car that will fit with no modifications?
Posted: Mon Apr 20, 2009 1:05 pm
by SpEc_OpS
Posted: Thu Apr 23, 2009 5:02 pm
by Sigmaproject
So is your new box to suit wide or narrow block ;)
