Hey all,
I am currently undergoing my 1600 -> 2.6L conversion on my 77 HD galant.
While I have it all off the road and I am getting a tailshaft made I was wondering if there were any diff centers that bolt into the galants to make them LSD?
ie; l200 ute diff?
If there are no bolt in options is there something I can get machined or would the best course of action be simply to put the entire diff/axles from something else in?
(I am not particulatly keen in welding the diff as I know this is the easiest option generally).
Thanks.
Galant LSD
- EVL076
- S-G Veteran
Re: Galant LSD
you can get them, but the last 1 i seen was $800
better option, and cheaper option, would be cut down a diff from something else
im goin commodore diff in my galant, and then there is a better selection of diff ratios around too
- karl_2ltgc
Re: Galant LSD
Basic Answer is no.
Stock galant diff is little 8 bolt centre an skinny breakable axles.
Do a search for your options.
Plenty on here already.
Re: Galant LSD
Lethal G wrote:you can get them, but the last 1 i seen was $800
I'm with lethal
get a borgy from a commy/ r31 /falcon cut down then you get bigger brakes too
Re: Galant LSD
check this out, DanTurboLancer has some good info on this
http://sigma-galant.com/viewtopic.php?f ... 3ecfadeec5
