Hi everyone. Just wondering if there is a straight swap set of diff gears out there for the stock 8 bolt GB sedan diff? I've always run the Jap 5 speed box, and don't have any intentions of swapping it out as it's had plenty spent on it being reconditioned. Just wondering if there is a simple swap out there for diff gears to try and lower those RPMa on the highway lol.
Thanks
Diff ratios
Re: Diff ratios
You're after a centre out of a GE Scorpion auto, that's what I have in mine. It's around 3.55 or 3.6:1? Instead of the 3.89:1 in the Galants.
Re: Diff ratios
Cheers Dave. So the pinion and ring gear can just be directly swapped with that of the GE Scorp?
