Alloy auto narrow block bellhousings
SIR
Post by SIR »
Hi guys i have a bellhousing to suit an auto behind a narrow block which i was going to use for a t5 manual conversion but it is made of steel and too heavy.
Has anyone come across an alloy one? I dont have a picture of this one but on the trans side the mounting holes are in a nice circular pattern concentric to the input shaft, if that makes sense.
mstrrab1992
Re: Alloy auto narrow block bellhousings
Post by mstrrab1992 »
Not sure for what motor you need but a guy named bill hincher or hinchner or something makes them
stealth
Post by stealth »
But if you still want to do you own , I have a alloy bellhousing narrow block to borg warner box , would be good for a cut and shut
Cheers stealth
SIR
Post by SIR »
Stealth does it look something like this but alloy?
stealth
Post by stealth »
No thats a auto bellhousing
Cheers stealth
