Transmission sump plug
The 5spd in the LC is losing trans fluid from the sump. II had a look and there is just a bolt and there has always been that. should there be a washer under this bolt or will i need a new sump plug for the transmission. Can't seem to find a new plug for the gear box.
Re: Transmission sump plug
There should be some kind of o ring or washer for a sump plug, if there isnt just put one on, probably a simple copper washer would be easiest
is there a particular part number. I want to get this right as my neighbor is going to start whinging if it still leaks hahaha
Just a plain copper washer mate, just make sure it fits snug over the plug. Any car parts store will have a pack on the shelf.
