Gearbox oil question??
Hey guys, what gearbox oil, and how much, should i be putting into a 5spd manual jap and borgwarner gearbox, on the 2L Astron motors? thanks
Re: Gearbox oil question??
Hi kaoskitten9871, welcome to S-G. Any good quality gearbox oil will do the job, something with a synthetic additive to reduce gear and synchro wear is an added bonus. As for filling the gearbox, there is a threaded plug on the side of both the gearboxes - this is the fill point. I've used a squeeze bottle and a tube to get the oil into the case (fill it slowly so it doesn't gush back out everywhere). When oil starts to flow back out, there's enough oil in the box.
75w-90, buy 2.5 litres and youll have a little left over but yea pump it in till its up to the filler plug
Borg Warner 5sp boxes take automatic fluid. For real! I didn't think it was right and put the thinest normal gearbox oil in. It made it very hard to change gears.
Now I use nothing but Valvoline Max Life ATF in all my cars. It is a great oil. You really feel the difference even in my Jag and Land Rover.
GH Sigma Turbo no. 047
What the... well, I learn sumpin' new every day.Turbo047 wrote:Borg Warner 5sp boxes take automatic fluid. For real! I didn't think it was right and put the thinest normal gearbox oil in. It made it very hard to change gears.
yep, i was a bit dumbfounded when i went to check the box in my gj to see if it had anything in it, to then find it had bright red atf fluid in it. ofcourse it wasnt the same colour about 6 months later ATF fluid defiantly for the BW boxes. is there a workshop manual some where which actually recommends atf fluid as well?
