Hey guys i know how to tell the diffs apart (BW have bolts on back of diff, Japs have them on the front). But is there any difference in the centres?
Were there any differences in the axles? mainly number of splines on the end of them.
I have a Scorp 10bolt diff and im trying to figure out what other diff centres (not just ours, im after ford or holden etc) the axles will slide into. Im not worried about different widths of the diff as ill be chopping the centre out of it for a hybrid diff.
What i want to do is find an LSD that scorp 10 bolt axles slide in (with same number of splines) and then chop the LSD diff centre housing and part of the axle tubes from the lsd diff, do the same to the scorp diff and weld the LSD housing in place and end up with it being the same length with scorp brakes on the outside and keep the same 114.3 stud pattern.
Cheers Matt
Cheers Matt
