Quick search hasn't really helped so ill ask quickly here.
Putting a 4g54 and matching box into the LC lancer from a sigma im told, and was wondering if its a straight bolt in or the box is shorter/longer etc and tailshaft will need to be modified to suit? Manual to a manual. From a 32 to a 54.
Tailshaft question
Re: Tailshaft question
If its the same gbox yes
But there are many different gboxs as in shifter spots
So depends on if its the exact same box you will have no problem
Make sure there the same
Cheers stealth
Cheers stealth
No idea, i pick it up from newcastle in a few weeks. Guy is overseas so i wont know will its back here next month. Good to know theres at least a possibility its a bolt in job.
Its possible, I got a couple of different options here , ready made at least two different tailshafts , if it doesn't work , before you go getting one made to suit
Cheers stealth
Cheers stealth
What box will you be running?
Jap wide block 5 speeds have a larger spline than that on the narrow block (just change the front spline over).
If the 2.6 and 5 speed are from an early GE/GH Sigma the box will have short shifter location (same as Lancer 5 speed).
If the 2.6 and 5 speed are from a late GJ onwards Sigma the box will have long shifter location (you'll be hacking up you trans tunnel).
If it's a Borg Warner your tail shaft will be a different length. I have a modded tail shaft here to suit BW with long shifter location, and a fully reco'd 5 speed I would like to sell (best offer gets it). I have the receipts, never used, $550 spent just on the box.
Hmm yea no idea just told from a sigma. If it helps this is a pic of it - not much to see but it might help looks different than my little 5 speed 4g32 box. My box is horrible and grinds 3rd if shifted hard and needs a reco or replacement. buying this together was the next best thing so if i can feasably make it work then thats what ill do. Ill also be strapping a turbo to it so if say this box pictured is stronger than my one ill have more motivation to make it work etc.
![Image](http://i.imgur.com/7REJDbh.jpg)
Well, from that pic, I know it's a Jap box,
has Astron 2 head,
has the shorter shifter location,
What 'I' can't tell from that pic. If it's wide or narrow block.
Question is, how long has it been out in the open like that?
has Astron 2 head,
No idea, ive been told it was fresh pulled and in good running order.
Not fussed on wide or narrow block as its going in how it is together. As long as the shifter location will still poke through my centre console im happy.
Will find out in a few weeks when i go to pick it up i guess
Pretty sure if its short extension shifter location it will fit?
Yes, a short shifter location will fit in a factory 5 speed LC hatch gearstick hole.
