Hey guys,
I recently picked up a GJ Sigma with the 2.6 Astron 1.
When I got it RAA for some reason moved the dissy and it was idling really high and running on after being switched off!
I got the local mechanic to have a quick look and they sorted out the timing and idle problem but still having a few issues on the carby side of things?
If I sit at the lights and let it idle for a bit it fuels up and I need to rev the car before it will take off causing a lot of black smoke!
The other problem I'm having is if I accelerate past about 1/2 throttle, I'm guessing when the secondaries open it seems to run really rich and black smoke comes out again!
It caused the car to backfire today and blow a decent sized hole in the rear muffler!
The car starts fine and runs well driving normally but does have a slight low idle!
Would it be as easy as the idle / mixture screws on the carby?
I'm changing plugs, leads, oil & filter tomorrow.
Thanks
Bloody carbies...
Bloody carbies...
Looking for a GE or GH Sigma in Adelaide... PM me
Re: Bloody carbies...
got a rebuilt carby for a GH 2.6 we were gunna throw away, but decided to keep it in case someone on the forums wanted one
wont be able to get it to you for a few weeks however
I had a similar issue a while ago with the coil and carby, it turned out the O ring in the carby had worn out causing the carby to flood with fuel and cause idle issues, so it might be a case of checking the O ring aswell as a service on the carby it self.
- 81GL
If you let the car sit and idle for a bit, does it eventually die? As in get too much fuel and cut out?
If so I'd be pulling the top of the carby off & checking the float level, check the float doesn't have any fuel inside it & Check the needle valve.
As for the secondaries, check all passages are free from obstruction.
If you don't have one already, get your hands on a Gregories manual.
Thanks for all the replies...
It ended up being a choke problem as it would just stay shut and wouldn't open when warm!
Also noticed the fuel pump dripping petrol as well but it's all sorted now!
