Valve clearance
- amgis_obrut
Valve clearance
anyone know the cold valve clearance size for a S1 2l astron?
Thanks
Thanks
Re: Valve clearance
.008" inlet
.010" exhaust cold
.010" inlet
.012" exhaust hot
cheers stealth
.010" exhaust cold
.010" inlet
.012" exhaust hot
cheers stealth
Re: Valve clearance
Really? My manual says
(hot)
inlet 0.15mm
Outlet 0.25mm
Cheater, yours are about 0.25 and 0.3, yes? Am I gonna be burning valves?
(hot)
inlet 0.15mm
Outlet 0.25mm
- amgis_obrut
Re: Valve clearance
camB wrote:Really? My manual says
(hot)
inlet 0.15mm
Outlet 0.25mm
stealth's are in inches
BTW cheers stealth
Re: Valve clearance
Yep, I know, and they are equivalent to 0.25 and 0.3 mil. Quite a bit larger gap than what I've been using.
Re: Valve clearance
I set up my valves hot at 0.008" ( 0.20 mm ) inlet and 0.010" ( 0.25 mm ) but the spec sheet for the cam gives these figurescamB wrote:Really? My manual says
(hot)
inlet 0.15mm
Outlet 0.25mm
you are pretty safe 0.008" and 0.010"
Re: Valve clearance
i'm with cheater i set mine the same.
gb galant efi 2.6 track toy
gj sedan hack car
gj sedan hack car
Re: Valve clearance
I fitted roller rockers with hydraulic lifters. Never have to worry about clearances ever again. Only down side is that they rattle for about 10 seconds after motor has started till they pump up properly. ;)
Re: Valve clearance
mate the biggest downside is the crapy hyd profile that
good for about 4600rpm
hyd cams suck bad
and you cant get a aftermarket one
cheers stealth
hyd cams suck bad
cheers stealth
Re: Valve clearance
that alright for playing in the dirt but if you wont to run a mans cam hyd dosent do itpanda wrote:I fitted roller rockers with hydraulic lifters. Never have to worry about clearances ever again. Only down side is that they rattle for about 10 seconds after motor has started till they pump up properly. ;)
Re: Valve clearance
then if you could get a decent grind the hydrolics would
"lock" at around 7000rpm ;)
not good
like cheater says get a man cam
cheers stealth
not good
cheers stealth
Re: Valve clearance
My rev limiter is set at 5500rpm, hydraulic lifters are OK till then, but beyond, your into solid lifter country. ;)
