Valve clearance
amgis_obrut
Valve clearance
Post by amgis_obrut »
anyone know the cold valve clearance size for a S1 2l astron?
Thanks
stealth
Re: Valve clearance
Post by stealth »
.008" inlet
.010" exhaust cold
.010" inlet
.012" exhaust hot
cheers stealth 8-)
camB
Contact:
Re: Valve clearance
Post by camB »
Really? My manual says
(hot)
inlet 0.15mm
Outlet 0.25mm
Cheater, yours are about 0.25 and 0.3, yes? Am I gonna be burning valves?
amgis_obrut
Re: Valve clearance
camB wrote:Really? My manual says
(hot)
inlet 0.15mm
Outlet 0.25mm
stealth's are in inches
BTW cheers stealth
camB
Contact:
Re: Valve clearance
Post by camB »
Yep, I know, and they are equivalent to 0.25 and 0.3 mil. Quite a bit larger gap than what I've been using.
cheaterparts
Re: Valve clearance
Post by cheaterparts »
(hot)
inlet 0.15mm
Outlet 0.25mm
I set up my valves hot at 0.008" ( 0.20 mm ) inlet and 0.010" ( 0.25 mm ) but the spec sheet for the cam gives these figures
you are pretty safe 0.008" and 0.010"
wheelnut
Re: Valve clearance
Post by wheelnut »
i'm with cheater i set mine the same.
gb galant efi 2.6 track toy
gj sedan hack car
panda
Re: Valve clearance
Post by panda »
I fitted roller rockers with hydraulic lifters. Never have to worry about clearances ever again. Only down side is that they rattle for about 10 seconds after motor has started till they pump up properly. ;)
stealth
Re: Valve clearance
Post by stealth »
mate the biggest downside is the crapy hyd profile that
good for about 4600rpm
hyd cams suck bad
and you cant get a aftermarket one
cheers stealth 8-)
cheaterparts
Re: Valve clearance
panda wrote:I fitted roller rockers with hydraulic lifters. Never have to worry about clearances ever again. Only down side is that they rattle for about 10 seconds after motor has started till they pump up properly. ;)
that alright for playing in the dirt but if you wont to run a mans cam hyd dosent do it
stealth
Re: Valve clearance
Post by stealth »
then if you could get a decent grind the hydrolics would
"lock" at around 7000rpm ;)
not good
like cheater says get a man cam :lol:
cheers stealth 8-)
panda
Re: Valve clearance
Post by panda »
My rev limiter is set at 5500rpm, hydraulic lifters are OK till then, but beyond, your into solid lifter country. ;)
