Ram tubes
Ram tubes
Hey guys im gonna be cutting my inlet manifold apart as it was made slightly wrong.
and i was thinking about adding some ram tubes to the inside.
I tryed googling and couldn't find alot of information on the topic.
All help welcomed.
Scott
All help welcomed.
Scott
Formerly known as QIKSIG
77 Lancer
77 Lancer
- cheaterparts
Re: Ram tubes
ram tubes are a way to tune the inlet lenth and have a smooth entry to your runnerCOBWBS wrote:Hey guys im gonna be cutting my inlet manifold apart as it was made slightly wrong.
All help welcomed.
Scott
on a N/A engine I use the formula of 90" / the revs you are tuning for
ie power at 6000 rev - 90/6 = 15" measured from the inlet valve to the opening of the runner including ram tube ( that is not ness completely correct but works out close and is from Phill Irvings tuning for speed ) and an easy formula to remember
as for a turbo manifold I'm guessing that would still hold true getting the pulse lenth right
will also gain even with the extra boost presure
hope that helps
Re: Ram tubes
Ahh yea i understand.
So do you think they are worth putting inside?
Or u jst think it would be better to make them all exacly the same?
tuning it for 6000 RPM should be heaps i rekon.
77 Lancer
77 Lancer
Re: Ram tubes
you can buy pre made ally "bell trumpets" and just weld in at the
point your runner ends and have the plenium surrounding that
keep them short as and try for a huge 11lt plus for volume (i assume
your running big boost through that massive turbo)
it will increase flow massivly
ps cheater there calculations for a third reflection intake possibly
not the best design for a turboed drag/road warrior
cheers stealth
cheers stealth
Re: Ram tubes
11 liters.. Holy crap.
I will put in the tubes
And try keep all the runners the same size.
Will post some pix..
Any idea of were i can get the alloy runners?
Scotty
Scotty
77 Lancer
77 Lancer
- cheaterparts
Re: Ram tubes
Scotty
I dont know my guess is that the sep runners will still work the same with a largestealth wrote: ps cheater there calculations for a third reflection intake possibly
cheers stealth
plenum ( tricking the wave to thinking its open atmo ) that will still work like N/A
the sound wave may slow a little with the presure of boost
it would be worth trying different lenth runners on a dyno with the same boost
could be hp for nothing
Re: Ram tubes
got ur power on yet cheater?
77 Lancer
77 Lancer
Re: Ram tubes
mate if i can make a plenium that 11.2 lts that fits into an evo engine bay
and there is there no problems with room and could easily fit in a lancer
engine bay
and a fews rough calcs and i reckon i could fit a 17.4LT in there(not that
there is any point)but i dont see how there is any lack of room
and yes i spent a shit load of time dynoing nicks lancer(evo3 with 4g63
stroker 2.4 with everything)and the best plenium was 11.2 lt
this car run in the 8 second bracket and has 973hp at 32 pound boost.
and remember that the faster the air speed the hotter the air
ps once you have mounted your plenium int the boot then you can put
your turbo in there to like spec ops
all jokes aside prove me wrong
cheers stealth
engine bay
cheers stealth
- cheaterparts
Re: Ram tubes
not yet - although I was told today that it should be getting done Monday ( I'mCOBWBS wrote:got ur power on yet cheater?
not holding my breath )
still my fingers are crossed
- cheaterparts
Re: Ram tubes
170 mm dia x 500 mm long plenum is 11.35 Lt
17 cm/ 2 = 8.5 so 8.5 x 8.5 x 3.1416 = 226.98 x 50 cm lenth = 11349 cc
I would have thought a 6 1/2 tube plenum would fit most eng bays
and I agree that is huge
just a thought
just a thought
Re: Ram tubes
simply when i finish making lethals one i will post the pics ok
and remember that the jun plenium of the rb engines is 14.8lt
and you can make 1200hp its all in proporsion
if you dont think it will fit go with what you can i was just making
a suggestion as i have done a couple of these sorts of things
you can do what ever you like its your car
no offence taken
cheers stealth
no offence taken
cheers stealth
Re: Ram tubes
the one i just measured is the early style with the red writing
it was 1.9lt
which is about write for a na engine
dont know if the later models are bigger or not
but i still say that the high boost needs shorter runners and more plenium
cheers stealth
it was 1.9lt
cheers stealth
- cheaterparts
Re: Ram tubes
the later ( TS on ) have longer and larger dia runners and althought the plenum is a different shape it would also be around the same size - volume - as the earlystealth wrote: dont know if the later models are bigger or not
cheers stealth
