Ok guys looking at rebuilding the sigma engine as im down in compression in 2+3 expected valves?
My problem is i've asked a few shops down this way that do 'rebuilding' apparently they don't assemble down here...
i have been quoted $1500 for a standard rebuild although they won't assemble nothing except head and crank etc...
just wondering how much a rebuild is expected to cost, or where people have gone to get done, im willing to courier the engine for a reliable build... ive been warned of a bussiness down here and would like a good build since im going to pay around 2-2.5k for it.
I have been quoted $3500 for my engine rebuilt with hyper pistons among other stuff that isn't quite as standard.
What should i look at getting if running Twin carbs??
i have a scorpion block and sigma head, i want to keep the block as its stronger so im told, and has been a better engine then the sigma ones i find...
also balance shaft removal, cam, new dizzy etc??
halllppp haha, may i also remind you all ive never rebuilt and engine or have the knowledge how haha
Engine Rebuild
Engine Rebuild
Re: Engine Rebuild (please help)
I reckon pull the head and see whats wrong, if it is just a gasket, chuck a new one on it and away ya go. If it is the valve find a good 2.0 head, new gasket and away ya go.
Get Mick to give you a hand.
knowing my luck id fix the head then the bottom end will go, then least i know its done, then i only gotta worry about panel work/rust/acyrlic then can turbo on full licence.
- cheaterparts
did you do a comp test ? then did you do a comp test with a couple of squirts of oil down the plug hole ?GC75 wrote:Ok guys looking at rebuilding the sigma engine as im down in compression in 2+3 expected valves?
that would tell you if it was rings or valves to start with
if you have to worry about how much its gonna cost then you cant afford it.
@ cheater - done comp test at the shop when carbs were being rebuilt, and he didnt squirt oil. He just expected it 'was' the valves. Thanks for the info.
@ astronturbo77 - well no that isn't the case, im adding things up... as the quotes i have got have been quite expensive compared to other quotes ive found here. Also was looking at buying a newer car as a reliable daily.
also quote superscan:
So $1500, how much am i looking at for assembley roughly, just looking at what i should be paying... or where i should go to with someone who has previous exp with having there engine rebuilt by particular people... as i said this town doesnt do a whole lot.. id rather pay someone to do it and get a warranty engine or something... theres one bloke in town but i have to wait a month.Build your own, at least that way you know what is going into it.
Cheap build would be about $1500
New ACL pistons and rings.
Bore, hone and deck the block.
Linish/regrind crank.
Re-seat valves and skim the head.
New bearings.
New timing chain and gears.
The High Compression and turbo engines I'm currently building are only going to cost me around $2000 each and that includes forged pistons.
That's because I'm doing most of the labor intensive work myself AND over time, I've bought a lot of cheap stuff through EBay.
- amgis_obrut
Re: Engine Rebuild
you'd do a V6 conversion and have change from $3500
give apm a call, they machine and assemble
or
Bob Bridge in nowra
or
Jack Croft in Tommerong
oh btw you wont get a warranty on a modified engine
or
Bob Bridge in nowra
or
- karl_2ltgc
Re: Engine Rebuild
Putting an astron together aint rocket science. Just saying.
Re: Engine Rebuild
Cheers mick, and karl hate playing with engines haha dirty things lol
