4g62?????????????? thoughts?
hey everyone, just been on ebay reseaching turbo engines and came across a couple of 4g62 engines. i went to wiki and all i could find is that its a cordia engine.are these engines any good? any potential power? im guessing its just a single cam 4g63.
Re: 4g62?????????????? thoughts?
Hey there,
once had a cordia turbo.It was OK...the starion is a much better car though.They had the 4G63 (2LT).The choice cordia is the one with the unleaded motor...pre 1984... which had 110KW from factory.I'd heard that doing cheap mods such as on the exhaust system are worth it.Terrible torque steer.
Being from a FWD vehicle you are faced with what gearbox to use in yours.
I wouldnt buy one myself.
For more info try the cordia website .Cheers![Exclamation :!:](./images/smilies/icon_exclaim.gif)
the 4g62 is a baby brother to the 4g63
its a 1800cc not 2000cc
cheers stealth![nerd 8-)](./images/smilies/msn_nerd.gif)
cheers stealth
- DanTurboLancer
does anyone know if they will bolt upto a Magna GBox, or can you turn them the correct way (North/South) and they match up to a RWD GBox??
the 4g6xxx range of engines has the same narrow and wide
g/box bolt pattens as the 4g5xxx range
![ohhh :o](./images/smilies/msn_surprised.gif)
cheers stealth
If you want to get that nostalgic feel into your car, then go for the 4G62.
Otherwise, if you want more power, then the 4G63 is the way to go. It would be nice if you got those coming from the early LanEvos.![grin :D](./images/smilies/msn_grin.gif)
I'm actually leaning towards one of these for my Scorpion, as I can pick up a complete engine with around 70k km for around $400. If you ignore the missing 200cc they are every bit as good an engine as the SOHC 4G63T, and considerably more common.
Josh
Josh
