Head Gaskets
Head Gaskets
I need a head gasket that will not fail. Has anyone any suggestions.
I started with a Montorque, that fail after 5000K
That was replaced with a OEM TP head gasket. That has failed after 20,000K.
The head and block were both square and OK when I replaced it with the OEM head gasket.
I am writing it off to building the engine for high compression.
I think a copper head gasket is in order, can anyone recommend where I can buy one from?
I'm getting sick of the clutch slipping due to oil seeping down the back of the block and into the bell housing.
Thanks,
Jamie
Thanks,
Jamie
- amgis_obrut
Re: Head Gaskets
how much compression
I have a few oem head gaskets and they're monotorque gaskets
Copper gastets are good for sealing in compression and thats about it
Re: Head Gaskets
you tried that copper-coat stuff? or hylomar? i dont change headgaskets without it...
Re: Head Gaskets
I still use a mono torque and run 11.2:1 comp no problem I do coat each side with coppercoatJamie wrote:I need a head gasket that will not fail. Has anyone any suggestions.
Thanks,
Jamie
is the problem an oil leak if it is theres no where at the back of the gasket that has oil under presure
theres an oil return which shouldn't leak
about the only place I've had problems of oil leaking at the back of the head has been the rocker cover
around the rear cam bearing it alway needs some silicon put in the corners
but if you still wont to get a copper h/gasket try ridgecrest I've used them before heres the link
http://www.ridgecrest.com.au/
Re: Head Gaskets
As Cheater has stated you will not have a head gasket failure for oil at the back.....
I will always run hylomar on my head gaskets and have never had issues. What torque settings are you using? do you torque things down in the three stages? when they have failed have you studied the head gasket to see where it let go? My head gasket in the 2.6 is still going strong after 35,000K and the coupe had one done almost 40,000K ago should be good enough to run OEM gaskets without issues.
Ridgecrest is the goods if you truely want copper but I am not sure I really see the point.
- 81GL
Re: Head Gaskets
Oldn Good to see you gracing us with your presence again
Jamie, from memory your running an astron 2 head from a magna on the 2.6 yeah?
-Rocker cover sealing in the corners where it goes over the cam tunnel? (i think thats what cheater is referring too?)
-Did you shorten the cam shaft? not leaking through there?
As above, technically it is possible... but pretty improbable
Nick.
(Astron rocker covers... they really are shocking things!!)
Nick.
Re: Head Gaskets
I used to always use genuine OEM rocker gaskets.(Can you still buy them?) Many others don't sit in the radius on the cover correctly.............
Roger
Roger
Re: Head Gaskets
its not the head gaskets mate, i think the deck of the block isnt straight. get a propper straight edge and some feeler gauges and check for warpage. Are you getting the cylinder head machined each time? this is essential. When replacing the head gasket are you cleaning the block with emery paper on a flat wooden block? the block surface has to be imaculatly clean, clean out the bolt holes with compressed air. Make sure the head hasn't had too much machined off and the bolts are bottoming out before it torques the head down. And last question, are you following the head bolt torque sequence? ie working your way from the center out?
Re: Head Gaskets
your back Oldn where have you been hiden ?81GL wrote:Oldn Good to see you gracing us with your presence again
Re: Head Gaskets
I have been using a Ridgecrest copper gasket for nearly 10 years. The block is O ringed
Had water seepage issues with Coppercoat. These were cured with a dose of Bars Leak
No problems at all now that it is coated with Hylomar. Should outlast the life of the engine.
Re: Head Gaskets
Long story short Steve... in last 3 years I have had my wife disappear, she took my coupe, had cancer dealt with and have had a heart attack all in all nothing major really.. :S just trying to piece my life back togethercheaterparts wrote:your back Oldn where have you been hiden ?81GL wrote:Oldn Good to see you gracing us with your presence again
Re: Head Gaskets
astronturbo77 wrote:its not the head gaskets mate, i think the deck of the block isnt straight. get a propper straight edge and some feeler gauges and check for warpage. Are you getting the cylinder head machined each time? this is essential. When replacing the head gasket are you cleaning the block with emery paper on a flat wooden block? the block surface has to be imaculatly clean, clean out the bolt holes with compressed air. Make sure the head hasn't had too much machined off and the bolts are bottoming out before it torques the head down. And last question, are you following the head bolt torque sequence? ie working your way from the center out?
Top advice!!
