Im putting an evo 4 4g63t into my sigma... just wondering whether anyone else has done this before?
i no a fair few people have put older style 4g63s in but havnt seen any new style...
4g63t evo 4 into sigma
1981 GH TURBO Build No257
1984 GK GSR
1984 GK GSR
Re: 4g63t evo 4 into sigma
Not many people go with shoving evo4 engines into RWD cause the evo3 is so much easier to do. All the mountings are there from the evo3 to bolt in with off the shelf parts without having to worry about gearbox's and custom engine mounts. All that pretty much needs doing for the evo3 is cut and shut the throttle body around and a custom exhaust manifold and dump pipe.
Hey silmayurbo,
I am pretty sure your going to have problems with the evo 4 set up beening that the exhaust and inlet are in reverse to the evo1,2,3
I'm asuming if the manifolds are in reverse so is the starter motor and if that is the case it would not bolt up to a standard sigma gear box
I pretty sure thats why everyone uses the evo1,2,3 set up, the bottom ends are similiar set up to the 4g in the starion's
SRGALANT
SRGALANT
The guy at City Dismantlers said that he'd seen an EVOIV+ engine in a RWD car, but it's the same guy that was telling me there was 4 different ECUs for the TR/TS magna, and they are that different that plugging the wrong one in to the wrong car/loom would fry it.
Lots of info on putting 4G63's into RWD cars on http://www.austarion.com
Agree, Evo 1-3 are a lot easier conversion.
the evo 4-9 engines have a different bellhousing pattern to the
1-3 engines there is no rwd available for this
but ckeck a website called "project zero.com"
its in the us but he's leading the way in rwd conversions
cheers stealth
cheers stealth
- turbosigma
yep - Bill has started - http://projectzerog.com/forum/viewtopic.php?t=1407stealth wrote: but check a website called "project zero.com"
cheers stealth
