Hi, was just wondering what mpi intake manifolds bolt straight onto g63bt heads? Minus has to cut and swap ends.
And also, anyone have a custom exhaust manifold they want to part with?
Thanks for any help!
Mpi intake manifold
Re: Mpi intake manifold
Big port or small port ?
Evo 1-3, vr4 or rvr?
Or evo 4 onwards ?
What are we talking about here
Cheers stealth
Or evo 4 onwards ?
Cheers stealth
I'm not sure what ports? I spose big port?
Engine is out of a '83 turbo starion if that helps.
So its a single cam ?
Cheers stealth
Cheers stealth
Yes sorry, Single cam turbo
L300 van manifold bolts straight on. Very common swap on a Starion.
Thanks man. Do you know if you can keep the starion dizzy? And just use l300 loom?
You can use the station distributor, I think the ecu you use will dictate what wiring etc you use.
You asked about a costom manifold? What turbo are you using?
With the l300 mpi manifold you could use it all ( the throttle body would be above the rocker cover ) and use a custom pipe to your existing turbo or use half the l300 manifold , custom plenum, bigger throttle body facing the front for connection to an intercooler
I am using part of the l300 manifold, ea falcon throttle body, Toyota prado intercooler, evo7 16g turbo on a custom manifold ( I got 2 sets of flanges laser cut )
Using a microtech ecu , I had to lock the distributor
I hope this lot of bable makes some sense
Simon
Simon
