OK so since I bought my lancer. I have had suspicions that its not running 100%. And for the life of my can't put my finger on why. From what I can tell everything is ok? It just doesn't seem to have much oomph as it should. Now I know they're not power houses. But this is what I'm experiencing.
It doesn't seem like the car has power. Vaccume advance checks out. I know the vaccume secondary actuator works cuz I can suck and hold vacuum. But the car feels powerless from about 3000 onwards. And recently following another lancer only with a single carb (mine has twins) and it pulled away by car lengths. And I have twin carbs. Something doesn't seem right.. Now I thought it has something to do with timing and I still do. Because I've advanced as far as I can. And still the car will not "ping" under load. I'm not sure what degrees btdc its running at ATM. It was set at 7 with a timing light. But I've adjusted it as far as the adjustment would let me. Which what at least 3cm. And it didn't seem to make a difference at all. Any thoughts
Timing issues? Or not. Sure.
Re: Timing issues? Or not. Sure.
Should be 5 at idle
And 32 to 40 all in at around 3000 rpm
Can be checked with a digi timing light
But its more likely you have a low comp engine therefore much less go power
Cheers stealth
Cheers stealth
The owners manual I have with the car says it should be 13° btdc for twin carbs model. What should the compression be in each cylinder? Because I'll be checking all that this weekend.
Have a look in your workshop manual
Mine says 1027 kpa per cylinder
Cheers stealth
Cheers stealth
So what maximum revs does it get to?mstrrab1992 wrote:But the car feels powerless from about 3000 onwards.
What I'm thinking here, if the vacuum diaphragm (for the secondaries) has been replaced with one from a single carb, then it wont open with the vacuum that is meant for a single carb (I've been there and tried this). The spring in the diaphragm is much lighter for a twin set up.
^Got a pic of your diaphragm?
What's your fuel pump like? Does it have good pressure?
keep in mind too that you werent THAT far behind, and my carb was just rebuilt, i have a new fuel pump, and compression is spot on etc.
Could it be the driver?
LOL. Just kidding.
LOL. Just kidding.
Its got an electric facet pump so I assume the pressure is alright.
I'll get a pick of the diaphragm
The vacuum advance diaphragm was a bit stiff. It doesn't move as much as I think it should freed it up a bit more
I have 175psi in each cylinder. Just checked. Not sure what its ment to be.
I hope its not the driver or I must have to go back to drivers ed.
A problem this irritating, its probably going to be Murphy's Law and only be a 50c part that's really hard to diagnose thats causing ur dramas. Hopefully its only something cheap an easy to fix
Me and murphy are on a first name basis so I'm sure it is.
