LB with 2.6 injected problems.
tealesrally
Post by tealesrally »
Hi All,
Looking for ideas. My car runs fine and the will act like its got a flat spot for a while. It will get worse and worse and then eventually die. Sometimes it will come good when driving.
I have replaced fuel lines and looked at several sensors to determine what was wrong with no luck.
The ECU is a AW311487 and I was thinking of replacing it. Should I and if so does anyone have one or similar.
Any ideas on what else it could be? Its driving me nuts.
notstock88
Re: LB with 2.6 injected problems.
Post by notstock88 »
a picture would go a long way. can you snap a photo of the engine and ecu?
mstrrab1992
Post by mstrrab1992 »
I'm not familiar too much with fuel injection. But it could be fuel pressure? Or one of your injectors is playing up. Personally I don't see a ecu having that type of effect bust as I say I'm no expert.
