Webber woes
Webber woes
attempted to fit my twin webbers to the old scorp motor for shits and giggles till it blows up (new motor still in progress), pulled the stock manifold and carb off and set to work.......... hang on a minute, damn air-con hoses are in the way, seems i cant have air-con and twin webbers. no matter i can make that sacrifice so off with the air con piping and on with the webbers, ill get some fancy custom piping done later to sort out the air-con. webbers on, now just to bolt it all down.. hang on a minute, it doesn't fit there isn't enough space left around a few of the studs for the nut to clear the manifold, cant even get a washer on there now to take it all off again and put the stock gear back on so im mobile again and can take the damn manifold back
RWD Mitsubishi - Love the unloved
Re: Webber woes
can you get the manifold nuts on if you back off the nuts that you did get on..so that they are only on by a couple of threads.. and you can pull the manifold back and get more clearance for the difficult nuts ???
Re: Webber woes
^Yep, just like Sigmaproject said.
Loosen all the bolts you have on back off again, and start all of the nuts together, and tighten each of them a little bit at a time.
Re: Webber woes
unfortunately not guys, the space just doesnt exist. did the mission out to the guys i brought it from, told to use allen key bolts instead of the studs in the head, adn grind a bit off the side of the manifold if i want to use washers, wasnt exactly the solution i wanted to hear from the workshop but as long as it works i guess
Re: Webber woes
and i did try walking the nuts on a bit at a time, just in case anyone was wondering
