guys ur gona laugh at me, but whats behind these plugs? water or oil?
coz i hav a water block problem in my block so hoping there is a way to free it up without takin engine apart haha
welsh plugs
welsh plugs
Re: welsh plugs
that would be water man
Re: welsh plugs
sweet. before i rip em out can you buy a set for a 4g33 at repco or somewhere?? (1400)
Re: welsh plugs
no idea what size they are man but yer id say so
Re: welsh plugs
shuggy repco and places like that sell welsh plugs by the size of the
plug so when you remove your ones either take that with you or
measure the hole it came out of
cheers stealth
cheers stealth
Re: welsh plugs
yeah cheers bois
just dril a hole int the middle of the plug and pull it out the easiest way?
Re: welsh plugs
nup,shuggy wrote:yeah cheers bois
tap them in squarely till it moves in a bit then tap in one side carefully 'till it "turns" so you can use some slip jaw pliers to hook on to the now raised edge and pull it out of the block without scratching the hole too much,
DO NOT knock it all the way into the block it will get lost and cause cooling system problems
Re: welsh plugs
thanks man, legend
