Miscellaneous
Gazza
Miscellaneous
Post by Gazza »
Hey, my name's Gary.
I'm just wondering if anyone knows where to get some various items for a 1975-4G32 fitted to an LA Lancer... (I'm not very knowledgable about anything to do with these things)
These various items include:
*'Main' Wiring Harness
*'Performance' Head, or Cam and valves/springs
*Double-Clutch
*Various 'Performance'... things
Sorry about my ignorance towards... everything I mentioned. Gotta learn sometime.
Thankyou for any replies and help... :)
aussiblue
Re: Miscellaneous
Post by aussiblue »
For the wiring harness you'll need to adapt one of these or similar http://www.ebay.com/itm/21-circuit-Univ ... es&vxp=mtr. or something from here: http://www.painlesswiring.com/PDFCatalog/index.php or here http://www.rocketindustries.com.au/pdf/ ... ion_03.pdf
or if money is no object people like this will custom make one for you:
http://www.connectsource.com.au/products.php
Regards Blue
aussiblue
Re: Miscellaneous
Post by aussiblue »
And you will be hard pressed to find any performance parts for an engine that old; a turbo and/or a larger engine from a later model Mitsubishi would be the best alternative.
Regards Blue
boyracer
Re: Miscellaneous
Post by boyracer »
Buy another car ....
3x la lancer 2door
2x gc galant hardtop
1x gc galant wagon
aussiblue
Re: Miscellaneous
Post by aussiblue »
You can slotted and cross drilled front disks on ebay and a Japanese car importer should be able to get you a twin car and manifold setup from a related Japanese domestic model that will fit.
eg http://www.ebay.com.au/itm/Mitsu-LANCER ... 20c2befa27
and lowering springs http://www.ebay.com.au/itm/Mitsubishi-L ... 1c23686978
and rear lowering blocks http://www.ebay.com.au/itm/Mitsubishi-L ... 1c22a2840c
you can also replace the suspension rubbers with Nolathene, Super Pro or similar eg http://www.ebay.com.au/itm/SUPER-PRO-MI ... 256f4d9c8d
Regards Blue
aussiblue
Re: Miscellaneous
Post by aussiblue »
Regards Blue
Re: Miscellaneous
...yeah, that'll make a good daily driver :|
leen
Re: Miscellaneous
Post by leen »
You can get most things done if you have the money.Engine can be adapted machined retro fitted, clutches, exhausts,suspension,fuel systems it just depends how far you want to go.Have a look at Hoonboy to see what is possible.
Gazza
Re: Miscellaneous
Post by Gazza »
Thanks for the helpful replies everyone... :)
I've sorted a fair bit of stuff out now, but I shall use this info to help me get the rest of the way
Thanks again :)
