Gear box convertion .... Is it needed ????
was wanting to know if it's worth changing the gear box in lb lancer hatch ... I have done a far bit to the motor like port and polished head bigger valves ect ....and hoping to get to the 130hp atw .. Will the box hold or will I need another like a celica 5 speed or something .. And how would I go about it thanks for any help u can give
- DanTurboLancer
Re: Gear box convertion .... Is it needed ????
How are you planning on driving the beast?
If you are planning on enjoying it, but showing the 30 year old drivline the respect it deserves,
then you can enjoy many years of motoring...
If you are planning on thrashing hell out of it, then Gbox, Tail shaft and diff upgrades.
Check out the Driveline section and they have a sticky about doing Supra conversions, which would be basically the same as what you are looking at
But tell us more about your plans
I am a little unsure of the saturn manual gearbox strength but I am sure that they are very strong, and have been in a car with one coupled with magna injected 2.6..even a 4 speed!.Lblancerhatch wrote: was wanting to know if it's worth changing the gear box in lb lancer hatch ... I have done a far bit to the motor like port and polished head bigger valves ect ....and hoping to get to the 130hp atw .. Will the box hold or will I need another like a celica 5 speed or something .. And how would I go about it thanks for any help u can give
That would have had 90KW at least, so i think you are right.You may have to change your clutch.
Also..as above depends how you drive it.Cheers
Thanks all ... I was planning motorkana work for her as well as a street driven car so it will cop a thrashing a fair bit was given the race style in and out .. Make it a two seater flares front spoiler heaps of suspention work
in that case get yourself a supra g/box as the jap 5 speed WONT hold abuse for long
cheers stealth
cheers stealth
