LB Sedan leaf springs vs LB/LC hatch springs
SIR
Post by SIR »
Does anyone know if the LB sedan rear leafs are the same as that found in the LB/LC hatches?
mattys
Re: LB Sedan leaf springs vs LB/LC hatch springs
Post by mattys »
Hi Sir,
As far as i'm aware they are. I have put LB sedan leafs and galant wagon leafs in my LA.
If you go for the wagon leafs you get a stack of 5 standard!!!!!!!! Cheap and easy conversion. Lancer leafs are rubbish with the 2 standard stack. Make sure you grab the wagon u bolts and fish plate as well. 1 downside is you can't use your bump stops.
Cheers,
Matt.
stealth
Post by stealth »
mate ke-30 corolla fit also from memory
i run three and a half leafs its all personal preferance
cheers stealth (H)
