Quickest way to change front springs?
vjval360
Post by vjval360 »
What is the quickest way to get the struts clear enough to remove and replace the front coil springs?
looks like the hub un bolts at the bottom and the tower bolts , will that get enough movement to remove the spring cap?
lancerdarryl
Re: Quickest way to change front springs?
Post by lancerdarryl »
You need to completely remove them from the car to change the springs.You will also need a pair of Spring compressors to remove and refit the springs
