Hey guys, tried the search engine but can't seem to find my answer.
So here is my question I've heard the 2.6 g54b is a bolt in power house. I've had 7 starions all at once, trust me they were all running so I'm familiar with the g54b. MY QUESTION is i find it hard to believe there is a wide block and a narrow block because those are only for 4g63?
What i need to know is what would i need for the drive train for the 4g54b to be an easy swap? Would I use the stock starion transmission and drive shaft or would i use the stock 78 lancer driveshaft? As far as rear diffs go are there any i should look for to hold all the power that is a bolt in?
wiring will be a pain i know but would i have to use the lancer's ecu? or the starion's ecu?
Sorry for the pain Noob to this engine swap and car.
Trying to daily drive her and then restore.
Question g54b Engine Swap. 78 mitsubishi lancer/colt
