Rear Window Frame
79Scorp
Rear Window Frame
Post by 79Scorp »
Hey guys,
Just wondering if anyone knows where i can get a replacement one of these or maybe a second hand one which is not rusted through?
I would need the drivers side however, i just found a pic of one laying around but it is of the passenger side.
Should probably mention its for a '79 GE Scorpion...
Piccie!
Thanks guys
Tristan
tubby
Re: Rear Window Frame
Post by tubby »
hate to be the one to say it, but good luck finding one. I replaced mine with a pinch rubber channel i can post up pics if you want, does not look anywhere near as good as original but seals better.
79Scorp
Post by 79Scorp »
Damn!
If you could post up pics that would be awesome, thanks!
I might have to give fabricating one up a go and try to get it as close as possible to the original :-(
tubby
Post by tubby »
your best bet would be NOS malasia :banh:
webby
Post by webby »
Pretty sure I remember Rare Spares having a listing for them? Said they were for Galant hardtop/GE-GH Scorpion?
Edit:
http://www.rarespares.net.au/rarespares ... ct=RGDSL5A
http://www.rarespares.net.au/rarespares ... ct=RGDSR5A
These what you're looking for?
tubby
Post by tubby »
the rubber seal on the ge-gh model is removable from the metal frame. the metal frame on the window is the bit that rusts out. if you want a replacement you would have to find a secondhand one or a NOS 1/4 window. anyway this is my solution, its tricky to get the frame from the glass without ruining it so better to get measurements before you remove them if you wanna make replacements.
sorry theyre sideways :ban:
79Scorp
Post by 79Scorp »
hmmm that could work... the one on our car is pretty clapped out. its not leaking but just has expanded and looks crap.
sorry for the noob question but what is "NOS"?
webby
Post by webby »
Nitrous ;-)
Lol, means new old stock. Basically new in box original manufacturer parts.
tubby
Post by tubby »
mine had split the rubber and was noisy as on the highway thats why i took drastic measures.
79Scorp
Post by 79Scorp »
webby wrote:Nitrous ;-)
so i run "NARS" id forget about the rusty frame is that right? haha
nah i knew it wouldnt have meant nitrous but New Old Stock makes so much more sense! i might have to do a bit of research to see what i can find but if not ill give making a newone a crack :-)
