lowering springs
lowering springs
So, narrow body starion front lowering springs should fit straight into the front of the scorp from what i read. What kinda drop can i expect? anyone got any brand preference?
Re: lowering springs
The starion spring will fit straight into a GJ, GK or GL Scorp, but not the earlier models. Standard Starion springs are lower then the standard Scorp springs, but most aftermarket ones will probably use the same springs for both cars.
is there a list somewhere showing which name is given to which year of scorp? Mines a 1980 and is the older shape with sloping boot...? i have no idea if its a gj, gk or gl.
GH most likely.flyingbrick wrote:is there a list somewhere showing which name is given to which year of scorp? Mines a 1980 and is the older shape with sloping boot...? i have no idea if its a gj, gk or gl.
Have a look at the chassis number, it will start with the year model letters.
thanks for that.
I've tracked down an nz manufacturer who lists lowering springs for the Sigma GE-GH Sedan & Scorpion which is good!
-Nathan
-Nathan
Right so mines a GH. will starion front struts still fit in so that i can run starion brakes?
What model sigma struts are directly swappable into my vehicle?
information is so hard to find on these cars.
cheers,
NAthan
cheers,
NAthan
