starion brake upgrade quick question.
city hunter
Post by city hunter »
Starion brakes and rotors bolt right onto an 81 scorpion correct?
80's Hero
Sigmaproject
Re: starion brake upgrade quick question.
Post by Sigmaproject »
I guess people are not too sure. Your Starions are different , so maybe the Scoprions too.
But over here you need to swap over the whole Strut assembly ;)
city hunter
what about for the rear? It's good to find out te differences. It seems like there is about 1.5inches of differentce in the mounting bracket spacing betweeing a usdm 84 staz and a 81 scorp. All I know is I need to figure out something quick. These non vented front brakes with my 14b g54bt at 18lbs is gonna get me in trouble quick.
80's Hero
RXCORP
Post by RXCORP »
All parts required will need to be from a narrow 4 stud starion.
Rears will need the rotor and caliper which is a bolt on.
Fronts you will need the full strut assembly and knuckle arm. Springs should be identical as you can use the scorpion top hat on the starion spring.
if i reacall the widebody control arms are longer than the narrowbody and also the angle of the bearing mount is different also.
Shaun i still need to quote you on the parts.
city hunter
Remind me whihc parts? Also any news on that spoiler?
80's Hero
