... if so, could you measure the diameter of the water pump pulley for me ?
Reading between the lines in the workshop manual, I think the 4G30 may run the larger diameter pulley (133mm compared to 112mm on the 4G31/2/3). The part numbers are certainly different for the A51 and GA1300 compared to the GA1500 & GB.
Thanks !
Dave
Anyone running a 4G30 (1300) ?
Re: Anyone running a 4G30 (1300) ?
Surely someone's got an old 1300 motor sitting in the back corner of the shed ?
