gb galant diff
gb galant diff
just wanting to know how strong the gb galant diff is im thinking of entering it in burnout comps or is there any simple up grades that wont cost a fortune dosnt matter if it is a bit wider as i can flare the gaurds a bit.or if there are any other axels that will fit as it will be welded and the axels are bound to snap. cheers
Re: gb galant diff
i snapped 6 axles.. with a 2 litre engine a five speed and gb diff only broke one diff, though it was a cig (or boc) locker:(....it was axle tramp that really added to them breaking!
Re: gb galant diff
i only broke a pair of axels with my LA diff locked, was running a hot 2.6 5sp, tey arent too bad if u can eliminate the axel tramp
Re: gb galant diff
I understand (but can't guarantee, as haven't measured them) that GB wagons have thicker axles than sedans
Re: gb galant diff
I dunno what has what?? my ga had skinny toothpick axles...but gb sedan i wrecked had bigger ones?? there now whats in my ga... + the diff centre to suit them , axel tramp definitely twists and loads diffs!!
Re: gb galant diff
GA rear ends are different again (smaller) .... t& the diffs are made of cheese, which is a pity, as the early (auto?) wagons had a 4.3:1 diff in them.
GB wagons also have larger rear drums than sedans (9" vs 8" diameter).
When I pull the rear ends out of the 2 wrecks I have - which both have wagon rears - I'll measure them up.
Re: gb galant diff
thanks for the replys havent done any burnouts yet but how do you get rid of the axel tramp in the gb also is there any other diffs that will fit that are not so rare like a newer corrolas or somthing as there is no gb galants in adelaide that i can find or a pintara diff
Re: gb galant diff
when i changed the engine i noticed the gearbox mount was relly soft if i solid mount the box and engine would this stop the axel tramp? how much wider is a sigma wagon diff as when the 2.6 has had it i might even go 6cyl and i highly doubt the diff will hold.
Re: gb galant diff
Why would you want to do burnouts anyway ? All it achieves is putting unnecessary stress on the driveline & wearing out tyres ..... call me old fashioned if you will, but personally I can't see the point
Re: gb galant diff
From what I understand, Axel tramp is caused by:leigh7005 wrote:when i changed the engine i noticed the gearbox mount was relly soft if i solid mount the box and engine would this stop the axel tramp? how much wider is a sigma wagon diff as when the 2.6 has had it i might even go 6cyl and i highly doubt the diff will hold.
1. The springs bending up into an S shape (not good) because of the engine torque and tyre grip.
2. When the tyre "slips", the tension in the spring releases, which causes the axel to bounce.
3. When the tyre hits the ground the whole process is repeated.
BTW: The diff-to-tailshaft angle is dramatically changed by this action and can easily destroy the uni joints and tailshaft as well as brake an axel.
Re: gb galant diff
because its a cheap way to have fun legaly and we dont have a drag strip in adelaide
Re: gb galant diff
Cheers.[/quote]
so in other words make the springs as stiff as possible so they cant bend?
Cheers.[/quote]
Re: gb galant diff
Cheaper fix, is remove traction until the wheels are spinning fast enough.
A pair of windscreen washer bottles/pumps filled with water aimed at each wheel should do it, and probably cost less then $20.
I'd suggest oil, but it's probably not allowed?
Galant's don't axle tramp once you get the wheel up to speed (well they haven't for me anyway, not that I'm a burnout king or anything?)
Re: gb galant diff
Another cheap fix for axle tramp is buy a Sigma or Scorpion to do it with, as they don't have leaf rear ends.
Re: gb galant diff
ahhh dave?? burnouts are a hard one to explain why they appeal..........i personally just love em!...
burnout pads tend to be really grippy, my ga axle tramped big time on a pad...on street...smoked no probs with minor tramp... ive got an extra leaf (3 all up) and spring clamps added too! im considering making up traction rods...similar to a caltrac sort of thing
Re: gb galant diff
No, that won't fix it .. it's more complex than that. Basically, you are asking a simple leaf-sprung rear end to do something it wasn't designed for.leigh7005 wrote:so in other words make the springs as stiff as possible so they cant bend?
If you really want to eliminate the "problem", convert it to a 5-link setup with turrets, coil-overs & "slipper" springs a la Escort RS ...... or get a car with a more suitable suspension design for what you are trying to do !
Re: gb galant diff
Why would you go the caltrac-style option (ie. attached to the spring mounts, as i understand it ?) rather than a proper anti-tramp rod setup mounted to the axle housing & the bodyshell ?GLANT wrote:asimilar to a caltrac sort of thing
Re: gb galant diff
I am doing it like that diff mounts and body mounts....thats what i meant by sort of thing lol!!!! just got to get pivot points correctdavetrees wrote:Why would you go the caltrac-style option (ie. attached to the spring mounts, as i understand it ?) rather than a proper anti-tramp rod setup mounted to the axle housing & the bodyshell ?GLANT wrote:asimilar to a caltrac sort of thing
its on my to do list!!
Re: gb galant diff
flipped leafs with a extra added leaf, eliminate axel tramp.
Re: gb galant diff
you still only have the one same spring taking the "thrust" of the drive ...so to say???
Re: gb galant diff
a straight spring at ride height also helps matters
Re: gb galant diff
If you can stop the
This will cause other major handling problems.
Using a "ladder bar" connected to the BOTTOM of the axle housing will do the most good with the least amount of work.
Basically it stops the diff housing from rotating when you put your foot on the throttle.
The front (tailshaft side) of the diff wants to tilt up when under load. This is what causes the leaf springs to go into the "S" shape.
By putting the bar on the bottom of the diff, it actually helps straighten out the spring when it's under load.
NOleigh7005 wrote:so in other words make the springs as stiff as possible so they cant bend?
Re: gb galant diff
flipped leafs arent everyones cup of tea, but for some 'fun' sideways handling they are ok ha. it stops the spring trying to wind up, this is not talk but actual fact from my own personal experience in my lancer. but i would rather see some proper axel tramp rods setup off the top of the diff housing and proper stron mounting points for them on the floor pan.
Re: gb galant diff
more "a trailing arm" than a "ladder bar"...but yes i agree with all superscan811 says!
Re: gb galant diff
and every car is a bit different in its axle tramp behavior due to tyres, spring number, spring height shocker position etc etc! some have easy fixes some are just nuisances!
Re: gb galant diff
i will see how she goes when my extractors come if the axel tramp is to bad might just have to get somthing else.i was going to make this my daily driver but needs to much body work to look half desent as im an engine person not a body builder
- 72GalantGirl
Re: gb galant diff
Not exactly sure if this is the right place not used to forums but I am looking for either a diff center or complete diff for a 1972 GA galant. Anyone know what will fit that is similar or stronger and what ratio diff can standard coz this one looks ancient thanks
Its not about how much you spend.... Its about how much of the work you did yourself!!!
