clutches
clutches
hey guys i have a 1974 gb galant 4 door and is currently auto, i am in the process of converting it to a manual and was wondering what box to use on the 1.6. and does anyone know if there are still new aftermarket clutches available?
Re: clutches
a std clutch is fine for a std engine unless you abuse the thing.... aftermarket? not that I know of this is a old car no one cares ! if the engine is modified you can get button clutch/ hd pressure plate made up but thats more than most guys here spend on the car in total , Any 4/5 speed Galant ,Lancer and Jap Sigma ones will fit, check the distance betwween upper bolt holes to be sure, and search here and the old site for detailis
Roger
Roger
Re: clutches
I would have thought any clutch for it would be "aftermarket" .. I doubt you would find a genuine Mitsubishi one for it ?Torana68 wrote:a std clutch is fine for a std engine unless you abuse the thing.... aftermarket? not that I know of this is a old car no one cares !
Clutches for them are no drama - my GB rally car has an off-the-shelf HD clutch in it, but can't remember the brand. I think the box might still be in the shed - I'll have a look & see if there's a part no. or something.
Re: clutches
cheers guys yer i just pulled the box outa my lancer rally car nd the button clutch fits the 5 speed i have so yer ill get an old one i have re co nd changed to a brass button cheers
jesse
jesse
