GC Struts
Jordan1249
GC Struts
Post by Jordan1249 »
Whats Struts fit GCs ?
75glnt
Re: GC Struts
Post by 75glnt »
Ga-gh
But some bits are different... But they "bolt" in
Brake hoses etc may need changing. So again... Just the strut housing will bolt in... The brakes and lines will differ
Jordan1249
Re: GC Struts
Is that galant models and sigma or just galants ?
75glnt
Re: GC Struts
Post by 75glnt »
Ga, b, c and d galants.
Ge, and gh sigma
Jordan1249
Re: GC Struts
Ok cheers
75glnt
Re: GC Struts
Post by 75glnt »
:thumpsup:
And remember, be carefull when changing between models.. As I've said, some parts are different and may need modifying... I'm not 100% sure.
Gh struts in my gb, all I need Is the sigma brake hose. That's it. But I now can not run any smaller that a 14" rim as the brake will foul. So if you wanna stay 13" wheels, stay clear of gh struts, unless you wanna run a spacer
Jordan1249
Re: GC Struts
Could i use the GC calipers to avoid that problem of the 14" wheels ?
RaptorReed
Re: GC Struts
Post by RaptorReed »
Starion struts also fit with their knuckles too and their hub, but I'm sure they are like GH struts and require at least 14" wheels (no a galant caliper will not bolt onto a starion hub). Use your stock tops and springs on them and being that you guys didn't actually get widebody starions, flatties are the ones you would want. Scorpion also fit, but require use of their knuckles and hubs as well like Starions, both Starion/Scorpion use larger bolts and only two to bolt the strut to the knuckle.
Reason not use Widebody starion struts: require camber plates or other mods to correct the amount of positive camber you gained. I have widebody struts on my Coupe, but i took what I could get when I snatched the 5 lug hubs up to finish my 5 lug conversion.
Tim
94 Montero SR
79 GE Sigma Wagon
76 Galant Coupe
92 Galant VR4
88 Fiji Blue Starion
