Galant Diffs
Galant Diffs
Is there different types of diffs that GCs had as i got axles from a GC and the sealer bearing is way to big for my diff and then today i noticed that when i tried to put the right sealer bearing on the axle is alot thicker so is there a few types of diff and axles that went into the GC ?
Re: Galant Diffs
I think the wagons and sedans were different.......the Hardtop might have a slightly digger/stronger rear end since it was a 'sports' orientated car
The dedicated Galant enthusiast could help you out more than me....
Re: Galant Diffs
As far as I am aware there were only two types. Both 8 bolt centres but had two different size bearings and axles.
The Australian sedan and hardtop had the thinner axles and the wagon got the thicker (Same centre as used in GE Scorpion and early Sigmas)
On an international scale ALL Colt Galants of the era used the same 8 bolt diff but only base models got the thin axles, we always seem to get the pov pack, even when fully imported. Basically, In the rest of the world Saturn cars (Galant A5 and A11 sedans, hardtops and GTOs) got the thin diff and Astron cars and all wagons (Galant A11, A12 and GTOs) got the thick.
Re: Galant Diffs
well i got the diff centre and 2 axles off this guy that owns a wreckers 6 hours away and he swears they are out of a GC hardtop and and the centre bolted pefected into my old housing but it was only when i changed the bearings i noticed how much thicker these axles were
Re: Galant Diffs
The hardtop he got them from might have had the diff changed to a wagon diff, they are a direct swap.
All the centres are interchangeable with the only difference being larger axles, bearings and drums.
Re: Galant Diffs
so if this guy sends me the housing will my drums bolt straight on ?
Re: Galant Diffs
I believe so, it isn't something I have messed with, prefer just to go to disc myself, but I have heard of people swapping over to wagon drums on their sedans as they are bigger.
All this messing about you could have had a disc brake diff shortened for $600 - $1000 and you would have a stronger unit with much better braking and easier to service
Re: Galant Diffs
haha if i had the cash i would but on a very tight budget atm and need the car just on the road
Re: Galant Diffs
Fair enough mate, see if he will send you the housing and should be apples
