will a siggy turbo diff fit my gb?
hey guys, will a siggy torbo diff fit my gb?? all siggy's have the same track, so it doesnt matter what model. cheers
Re: will a siggy turbo diff fit my gb?
doubtful....more than likely have to be shortened
But from i know, he turbo diffs aren't any stronger or more reliable than any other (later) model sigma of any variant....im sure the Turbo diehard fans will correct me if im wrong
hmm. cheers scorpma. do you know any diffs that will go in without a cut and shut job. (other than leaf mounts)
Correct, Turbo diff is just as shit as the others! Only difference I have ever noticed though is I pulled the centre out of my first GH Turbo and it actually had a "window" which allowed me to lock it without pulling the centre apart. Not sure if that was a once off though. I've heard the galant wagon centres and axles are stronger than the sedans but I'm no expert.
hmm nah. im looking for discs. might have to cut one...
If your lucky, the EX Lancer diffs will fit
Again, the diehard fans will correct or confirm
81-85 i believe.
but from what i know of, none of them were made in australia....they are all imports, so they are hard to come by.....
Just for shits and giggles, u can try a Starion
hmmmmm, can you roll the guards or even run different offsets on the wheels to compensate the difference
not a 5" difference i dont think. if i was using flares id do it. but i'm not.. yet. i may do. i dont know how itll look with the bolt ons. could someone photoshop em on? i'll post the pic
with the white bolt ons and the matched track. same offset thats on it now. thanks alot
why not put Torana flares on it....you could call it and SL/R 1600 lol......that's something i'd do lol
no! i dont mind the smaller version you see on the 260zs and dattos.
i cant see them for some reason sorry
you and put a Sigma or Scorpion or Lancer EX diff in the Galant (need to modify mounts to leaf springs) as this is what i have done in one of my GB Galant's.
I used the Sigma diff origionally, but now have a Scorpion one to go in.
with the two different offset rim's i ran on the car it had the same track front and back and they cleared.
I ran it with a Sigma master, no booster, just a spacer to adapt to the different bolt pattern of the Sigma master.
The Galant diff can take alot of punnishment.
I am (slowly) working on a Galant diff with Scorpion disc's and caliper's, needs the axle hub to be machined a bit to accomodate the Scorpion disc and a bracket for the caliper to mount.
Refer this post for what i am doing. http://www.sigma-galant.com/viewtopic.p ... iff#p88873
Oh cool. Thanks for that mate
I'll need someone else to mod my diff as I don't have the skills.
I'll post the link for that pic instead of posting the pic
EX Lancer diff is identical to a Scorpion/Sigma diff.Scorpma82 wrote:If your lucky, the EX Lancer diffs will fit
A stock Scorpion diff will fit under your car no worries but you will need to make sure you get the correct offset wheels. If you wanted to run a 15x7 for example you would need a +25 or 30 offset.
