few interchangable parts questions
Sorry, I would have used the search function, but my phones being a pain . I've got a 74 gc galant and I've bought an import sigma. 4g63t. Are the front struts interchangeable? What about booster and master? Just want to get the best pieces I can basically. Cheers
Re: few interchangable parts questions
hey mate, if its a gh sigma, the struts will bolt in. but it narrows your track.
heres a link. hope it helps.
also, best throw 75wagon a pm as he knows more about it all. im pretty sure you need something off the galant as the gh struts foul with the sigma bit.
cheers,
Mick
cheers,
Mick
being a GC Galant you can fit a (Aus) brake booster and master to it with little hassle. As for a Import (most likely a GJ Sigma equivilant) i would not see any problem either.
An Import Sigma would (most likely) be running full Starion driveline (motor, gearbox, struts, brakes etc)
The strut's will simply not "just bolt straight in". you will need the steering knuckle that attatches the bottom ball joint (on the lower control arm) to the strut. Also you will need to change over the strut top hat (bit that bolts the strut to the body in the engine bay) to the one from the Galant
You will need to modify your lower "A" arm in the Galant to take the Starion ball joint as the break disc will rub on the "A" arm.
Thanks for the advice people. Narrowing track isn't any good, I'd rather go the other way if possible. What suggestions are out there for that? Trying to limit cost as much as possible.
