hi guys, i just finished rebuilding my wheel cylinder and found out whats the cause of the leak...its one of the piston that making the leak, its stuck and the other one moves much farther so the fluid leaks even the cup are'nt worn at all...
i'm just curious what makes the piston to stuck.?..even i know that i can replace the wheel cylinder w/o any problem....
brake drum wheel cylinder
- karl_2ltgc
Re: brake drum wheel cylinder
Brake fluid absorbs water over time, once it cant absorb any more water you end up with water in your brakes and the pistons start rusting causing them to jam.
Sometimes you can use some very fine sandpaper to smooth off the rusty bits and grooves that end up in pistons so that they will seal up and move freely again.
This is why your supposed to put new brake fluid in every 24 months.
I wouldn't have even tried rebuilding wheel cylinders when you can get them for $15 brand new an just bang them in.
