![Google :google:](./images/smilies/google.gif)
Combination Switches
Does anyone have a GA combination switch and a black door trim for drivers front door that isnt broken?
is of no use GOD DAMN IT!
The 20 year wait is OVER ! The GA is MINE I TELL YA , ALL MINE , BWAHAHAHAHAHA!
Re: Combination Switches
Combination switch?
aka combo switch
aka indicator/wiper stalks and its 'hub'
Combination Switch ie; Wiper/Indicator switch and assembly that goes around steering column, inclusive of the Hazard switch.
GA to GD and GTO switches are the same I believe. Only difference being plug wiring. I am sure if you got a later model switch you could swap the plugs and or wiring over to suit your car.
Thanks for clarifying this A112H...MAKES LIFE EASIER!GA to GD and GTO switches are the same I believe. Only difference being plug wiring. I am sure if you got a later model switch you could swap the plugs and or wiring over to suit your car.
