2.6 l engine build
Goz101
2.6 l engine build
Post by Goz101 »
Hi all,
I've decided to keep the carby setup on my Gh turbo.
I am going to rebuild the wide block 2.6 L that's in it but need some of your thoughts on the following;
1. What parts are recommended for lowering compression.
At the moment bottom and has flat pistons with decompression plate.
I know there is a lot of talk about deco plate but I had it on cordia turbo for many years and never had any issues.
I was told if I need to lower compression to use dished pistons and a quality gasket.
What is your opinion on this?
Where do I buy a set of dished pistons for 4g54?
2.I've been advised to use Magna M7 head.
Is this of TR magna?
3.Will this head have any issues with dished pistons?
4. With Magna head M7, I was told they have roller rockers
I was advised by the previous owner to use M7 head but to get rid off the roller rockers and use the existing camshaft and rockers of the current engine.
camshaft is aftermarket etc etc
5.I am missing a clamp that holds the pipe in place between turbo and intake manifold.
Can you buy this or has to be made?
Also I need clamps that connect carby to turbo
and
clamp that connects turbo and exhaust
Thank you all.
yno26galant
Re: 2.6 l engine build
Post by yno26galant »
Hey mate. Just completed a 2.6 efi turbo engine build
specs are pistons are:
-8cc dish with m7 head
copper 2mm headgasket with oring head
compression ratio is 8.22.1
camtech cam part no 705a (pretty sure) soild rocker arms with the swivel foot tappets
just made 260hp on 13psi atw
leoca64
Post by leoca64 »
and
pretty sure same size for original TO3. Just V band clamps
Mine were "Voss" ones . Were $50 each a way back. Mike Vine might still have a few.
Goz101
Post by Goz101 »
Thanks mate, I ll have a look
