sigma axels
leigh7005
sigma axels
Post by leigh7005 »
just wanting to know id all sigma axels are the same? and if disk and drum brake make a diffrence?
Sigmaproject
Re: sigma axels
Post by Sigmaproject »
My wagon originally had a drum brake rear end. I bought a disc brake rear and had bearing to suit the discs pressed onto my axles..so yes the axles are the same. But the bearings are different.
leigh7005
Re: sigma axels
Post by leigh7005 »
cheers for that how about wagon vs sedan?
Jordan1249
Re: sigma axels
Post by Jordan1249 »
Idk about siggy but i know with galants the wagons axles are a bit bigger and the drum brakes are also bigger on wagons for galants
Sigmaproject
Re: sigma axels
According to the GN model parts catalogue..everything is the same between wagons and sedans..except the actual housings.
Re: sigma axels
Wagon gearbox gearboxes and diffs are based on the GE/GH Sigma, ie: ALL Sigma wagons have short extension housings on the gearbox and all Sigma Wagon diffs have the same arms and spring arrangement as a GE/GH Sigma/Scorpion.
I know that GN Wagons have the Jap 5 speed gearboxes but BW diffs.
You can put a Jap diff out of the GE/GH Scorpion into the wagons ( The GH "10 bolt" diff is preferred because they are much stronger than the GE "8 Bolt" diff).
The benefit of the Scorpion diff is it has discs not drums.
