I am in the process of fuel injecting my Sigma, I have done most of the wiring but can't work out how to wire the XE throttle body, it has only 3 wires were the Magna throttle body has 4 wires
If anyone can help with this problem it would be appreciated.
Need help wiring up XE Throttle Body to Magna Head
- amgis_obrut
Re: Need help wiring up XE Throttle Body to Magna Head
OK if you look inside the Ford TPS the pins are identified top to bottom as ABC
A = Ground
B = Signal
C = +5v
Looking into the Mits TPS plug, (two small notches on the right one large on the left) the pins are identified top to bottom as 1234
1 = +5v
2 = Signal
3 = not used
4 = Ground
A = Ground
B = Signal
C = +5v
1 = +5v
2 = Signal
3 = not used
4 = Ground
Thank you amgis_obrut
I have been trying for weeks so hopefully it will be wired by Sunday
