i might be pickin up some 16x7 inch 2 piece mags,they come off a silvia and im wondering if im gonna have clearance issues?
ive got chopped springs so the car is draggin its bum a bit
bigger rims
- boogernissan
Re: bigger rims
Would depend on the offset I suppose.
Get who ever owns 'em to measure from the hub face (the back of the rim that bolts to the hub) to the outside of the rim. Then take your wheel off and measure from your hub to your guard. See how much room is left if any....
Re: bigger rims
A Sigma offset is around the +20 mark As you go wider the offset has to change, or you will hit the strut where your spring perch is. Look for something around the +10/15 mark. The rear shouldn't be a problem only your fronts.
- turbosigma
Re: bigger rims
running 17x7 +25 - but did hit the guard a bit depending on tyre width.
http://www.1010tires.com/WheelOffsetCalculator.asp
- boogernissan
Re: bigger rims
im trying em on before i buy so ill see how i go, cheers for the help,
heres a pic of them
![Image](http://i254.photobucket.com/albums/hh103/boogernissan/my%20cars/post-1196-125432199517_thumb.jpg)
heres a pic of them
