i have been rebuilding my engine slowly for a fair while and today i did some mesurements for CR and first stroke was wrong, thought maybe 2lt crank then bore is wrong WAIT ITS 2LT WTF?
now this engine has an astron II head BUT IS 2LT
I always thought it was a 2.6 because of the rocker cover.
AND spent hours going through old forums to find engine number codes and my block is factory turbo YAY (car is factory turbo)
ISSUES
head is wrong and very strange there is no 2lt astron II
some pics of the block
far as i know turbo had flat top pistons with a notch out on the inlet side for valve clearance.
engine in one piece
the question is can you put a 2.6 head onto a 2lt??
the head has been modified to suit the manifold there are welds on the studs
im really not sure about the whole thing if anyone could shed some light that would be great.
found to be 2lt blessing in disguise perhaps.
"Boosted is The Only Way To Live"
<Sigma Turbo No.177 >
<96 Astron Powered Triton>
<81 GJ Scorpion>
<81 GJ Scorpion>
Re: found to be 2lt blessing in disguise perhaps.
It would seem that you have a 2.0L Astron I turbo block & inlet manifold, but some one has fitted a modified Astron II head & rocker cover to it. Never seen that done before as its not easy to graft an A1 manifold onto an A2 head. ;)
I have a 2Lt too, how see that info ?sigtool wrote: AND spent hours going through old forums to find engine number codes and my block is factory turbo YAY (car is factory turbo)
GS/R power
From the Mitsubishi GH workshop manual - First number is engine size, second number is performance and the last number is the transmission.
531
2.6L, Standard Performance, Automatic
431
2.0L, Standard Performance, Automatic
452
2.0L, Turbo, Manual
531
431
452
2.0L, Turbo, Manual
<81 GJ Scorpion>
<81 GJ Scorpion>
- amgis_obrut
where is the engine number located on this engine?
the block has been decked engine number usual spot is gone
there is one stamped on the upper balance shaft housing
<81 GJ Scorpion>
<81 GJ Scorpion>
- amgis_obrut
thats the correct spot for the turbo engine
sigtool wrote:From the Mitsubishi GH workshop manual - First number is engine size, second number is performance and the last number is the transmission.
531
431
452
2.0L, Turbo, Manual
Excelent, thnks!
GS/R power
