That'l teach me
Sigmaproject
That'l teach me
Post by Sigmaproject »
It never pays to glote about something to do with Sigma's, without saying "touch wood " straight after making the comment.
A couple of posts back I was saying how well the Wagon goes, just like EFI.
Took it for a run yesterday. everything was perfect, as always :D Anyways, just as I was turning into my street, it started to miss, and the taco started to go bonkus. I just put it down to climate change and put it to bed, thinking that everything will be OK in the morning :roll:
Well that was the last time it actually run :cry: :cry: . No spark at the plugs, and nothing at the Coil. Changed the coil, made no difference :cry: :cry:
Everything in the dizzy is OK. Only thing left is the control module. I have a spare but by this time I was over it and just shut the bonnet and closed the shed. Maybe later :roll:
And I am open to suggestions ;)
sigmare
Re: That'l teach me
Post by sigmare »
Try bleeding the ignition leads :o
karl_2ltgc
Re: That'l teach me
Post by karl_2ltgc »
It will be the module or the coil. Check wiring as well.
Sigmaproject
Re: That'l teach me
sigmare wrote:Try bleeding the ignition leads :o
Yes I tried that. After I did it the clutch started to slip real bad.
karl_2ltgc wrote:It will be the module or the coil. Check wiring as well.
I replace the coil and module a couple of years ago when I had issues.
It finished up being a burnt and cracked rotor button. Was arching down the side of the rotor. Put the old coil back in with no luck. So the module goes in tomorrow night. Fingers crossed :roll:
Astron Boy
Re: That'l teach me
Post by Astron Boy »
Sorry, don't want to hijack, but, how do you bleed ignition leads.
panda
Re: That'l teach me
Post by panda »
If your ignition wiring is still OEM, check the fusible links in the wiring loom behind the battery. They sometimes overheat & burn & eventually break. Or the connectors to the fusible links often have a poor connection. ;)
karl_2ltgc
Re: That'l teach me
Swap the dizzy. I reckon its the little trigger thingy that picks up the 4 bits that spin round.
Sigmaproject
Re: That'l teach me
Astron Boy wrote:Sorry, don't want to hijack, but, how do you bleed ignition leads.
I think we should let Sigmare handle this one ;)
Astron Boy
Re: That'l teach me
I have just never heard the term used before.
So, in reading it, it looks like a mistake. :?
Sigmaproject
Re: That'l teach me
karl_2ltgc wrote:Swap the dizzy. I reckon its the little trigger thingy that picks up the 4 bits that spin round.
A couple of years back I had a bad misfire and the odd backfire that sounded like it would blow the muffler aprart. Thats when I replace most of the ignition circuit with new bits. Made no difference until I had a dizzy rebuild by Scortcher in Vic. Havent had a hint of a problem since.
Until this little episode :roll:
So the dizzy is only a couple of years out from a rebuild. I am going to go through all of the connections from the battery to the coil. And there are plenty of them. :roll:
Sigmaproject
Re: That'l teach me
Bought a module from Repco today. No change out of $50.00
Look like it will have to wait till tomorrow night :roll: I have to fit a new seatbelt to my 1 Tonner tonight. The whole retracting spring shot out its housing and hit the dash :shock: There was coil spring everywhere .Scared the crap out of me at 100kph
Sigmaproject
Re: That'l teach me
Well happy to say it was the control module. Started first kick. Hasnt done that for a while :) The GN has to control monule on the side of the dizzy. The failing Tacho is a good indication of a control module problem bacause the tacho gets its signal from the module.
Happy times again :D
