Does anyone know if and where you can buy the alluminium heat shielding like what's used on modern cars? I'm getting an exhaust fitted soon and the extractors are going to run close to the steering box and seeing as I've finally tracked down a good one, I don't want to stuff it by cooking it.
Alternatively, will the thin alluminium sheeting you can buy from bunnings do the same job? it'd probably work out cheaper.
Heat Shielding
Heat Shielding
- WagonWheel
Re: Heat Shielding
Repco and bursons sell the heat shield material. Acl make it you just cut it to what ever size shape you need. Same stuff they use in modern cars.
Re: Heat Shielding
Nice one!
Thanks for that.
Thanks for that.
Re: Heat Shielding
i use this stuff, its expensive, but it is the shit to use.
ive made turbo heat sheilds, manifold covers and floorpan sheilds out of it.
http://www.aclperformance.com.au/prod_heatshield.htm
you can find it cheap on ebay
- WagonWheel
Re: Heat Shielding
Yep. That's the stuff. Exactly what I was talking about. It's good stuff
